Possible front jack locations?
Old Oct 24, 2020 | 01:44 PM
dgdarien's Avatar
Default Possible front jack locations?
So I jacked up my car as usual, using that little spot in the front, towards the driver side to jack up my car and the whole core support frame bent. Resulting in me having to hammer the radiator support back down in order to get the hood to close.
The car had been in prior collisions so I'm under the impression that a weaker replacement was used. What are my options for jacking the car up now? I'm told the front tow hook/points and LCAs are not viable locations.
Old Oct 24, 2020 | 06:53 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Possible front jack locations?
Originally Posted by dgdarien
....................The car had been in prior collisions so I'm under the impression that a weaker replacement was used. What are my options for jacking the car up now? I'm told the front tow hook/points and LCAs are not viable locations.
underneath the car... a few inches from the front wheel well.
Old Oct 25, 2020 | 09:57 AM
dgdarien's Avatar
Can you be a little more specific?
Old Oct 26, 2020 | 11:47 AM
chrysler kid's Avatar
Behind the front tire under where the door and fender meet under the side skirt you will find a metal tab hanging down
Old Oct 26, 2020 | 11:49 AM
dgdarien's Avatar
Oh there, yeah that's where I place my jackstands once the car is jacked up. Am I just gonna have to lift the car on each side one at a time from now on.
Old Oct 26, 2020 | 05:46 PM
Lasty K's Avatar
Last resort would be where the front LCA mounts/bolts to, lift it up just enough to fit a jack stand at the side point.
Old Oct 26, 2020 | 07:17 PM
egsleepercivic's Avatar
I am guessing your car was wrecked before and had the core replaced or something
I use the front jack point on both my 95 integra and 93 si all the time without issue, it is literally there so you can use it
Old Oct 26, 2020 | 08:06 PM
dgdarien's Avatar
Yeah the car has been in previous front end collisions but I hadn't heard that bodyshops used cheaper (and weaker) replacement core support frames until now. I had been using that front jack point for many years before this.
Old Oct 31, 2020 | 03:17 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
My floor jack only lifts about 16 inches so I put a hockey puck in the dish and I lift the front lower control arm just behind (engine side) of the lower ball joint, This gets me a few more inches of lift for putting in the jack stand at a reasonable height. That's a trick I've been doing for ages now.
