8th gen Accord Coupe V6 How to make a down stream O2 heater simulator?
So I have to replace the downstream O2 sensors quite often due to the heater in the sensor going bad. I'm getting quote tired of doing this, as the sensor part works just fine. I want to emulate the heater circuit. I know that the heater circuit shows 5.5ohms on brand new sensors. What else is needed to complete the circuit other than a 20Watt 5ohm resistor? Help will be extremely appreciated. Thank you.
Besides,the heater circuit is dynamic,its values vary in response to PCM commands,you cant replicate it.
Why not just find out what is causing the heaters to fail so often? They should easily last 10+ years. If youre replacing them more often than that,you have an underlying issue.
- There is a short circuit
- There is an open circuit
- OR If there is excessive current draw in the circuit
