Is it possible
Old Oct 11, 2020 | 06:09 PM
Jeremy64's Avatar
Default Is it possible
Is i possible to turn my auto into slap style or flappy style shifter. Theoretically yes but has it been done
i ask because i miss having a manual and do not want to swap car to manual. If so how would it be done
Old Oct 11, 2020 | 09:16 PM
99stockcivic's Avatar
Default Re: Is it possible
Yes, there is a company that makes a universal paddle shifter kit for all automatics:
You need this:
https://paceperformance.com/i-238601...ontroller.html
and this:
https://paceperformance.com/i-238363...h-display.html
But I would call them to make sure you have all the parts necessary.
Good luck.
Old Oct 11, 2020 | 09:23 PM
Jeremy64's Avatar
You need this:
and this:
Good luck.
Thanks for the help but at that price not a reasonable price manual swap would be less
Old Oct 11, 2020 | 10:09 PM
MAD_MIKE's Avatar
MM Gruppe B
97-02 Accord SiR CF4 had the S-Matic transmission where the engine had a manumatic shifter that allowed for manual selection in any gear with control via the shifter.
I believe it was the same transmission as the 98-02 USDM H/F series, which would mean you wouldn't need the complete transmission just the harness/PCM/shifter to get similar functionality. But you will need to verify that. If you have emissions testing, this will not be an option as the JDM PCM will not communicate with USDM OBDII.
For the 90-97(USDM) you could manually shift the transmission via control of the shift solenoids as the various computations of ON/OFF would select the various gears. But to integrate that as well as maintain normal automatic control via the TCU would be a bit more work. There are various aftermarket controllers and stand alone units out there to allow paddle shifting. If you go this route the biggest item you would want to copy from the original TCU programing is the grade logic for the TC lockup functionality.
Old Oct 12, 2020 | 10:10 AM
Soinds like you went in a circle. Just swap the manual in, you will be happier and its the cheapest thing to do.
Old Oct 12, 2020 | 11:45 AM
Jeremy64's Avatar
manual swap is definitely the way to go i just wanted to if options where available. Thank you all
Old Oct 12, 2020 | 04:34 PM
2001GSRSC's Avatar
5 Year Member
Crazy.
The way, is to start with a manual transmission vehicle.
My neighbor bought his 5 speed 96 Accord for $800. Clean body 120k. ...He spent over $1200 on wheels for it from Tirerack.
Cargurus has 3 of them within 100 miles.
Old Oct 13, 2020 | 03:37 AM
true, unless you have some totally restored vehicle, it proabbly is easier to just swap cars, sell yours, buy the manual.
