Fuse 44 / 23 keep popping! Help pls
Just purchased this ek coupe and it has a short somewhere. So i have been trying to trace this short down but can’t find it at all. The fuses keep blowing when car is turned to on position however whenever I unplug connection c101. Fuse 44 and 23 related or different shorts?
Two separate shorts.
Fuse 23 protects the SRS computer. Has the car been in an accident?
What year Civic? Are saying that unplugging C101 prevents fuse 44 from blowing?
1997 honda civic dx sohc non vtec d16y7
I just purchased the car so i'm not sure, it is clean title though, however i do see dent on passenger side front clip. Will the srs system prevent the car from starting after i fix the fuse 44 short?
Also unplugging c101 the fuse does not pop.
I then plug that back in a unplug injectors and iac. fuse pops
i plug those all back in unplug connector c130 and fuse does not pop
im trying to unplug c116 right now but cant seem to get it off, it is the grey connector that is next to the blue correct?
Last edited by 817Ekcoupe; Oct 11, 2020 at 06:26 PM. Reason: forgot to add something
I unplugged connection A on ecu with everything else plugged in and the fuse does not pop.
Couldn’t find any, buddy gave me an auto ecu will it work? Plugged it in and the fuse doesn’t pop however the fuel pump isn’t priming. Main relay clicks and is working though
Try this test:
See ECU connector A diagram in post #4.
Unplug ECU connector A.
Use a wire to ground pin A16 (Grn/Yel wire) to the metal frame under the dash.
Turn key to ON(II).
Does the fuel pump run?
Buddy gave me a 1999 civic sedan automatic ecu
it has the same p2e code but a90 last three digits. Also a lot smaller than my original ecu.
ground that ecu wire on my original or buddy’s ecu
Your car has an OBD2a ECU, whereas a 99 Civic has an OBD2b ECU. Obd2a and OBD2b ECUs are not interchangeable.
Replaced fuses just to make sure tried again and still doesn’t work. Pump only works when jumping 6/7 on main relay. However I’m pretty sure this main relay is good I feel it click once when turning key to on. Had multiple Duralast ones before and didn’t feel or hear the click. Got this main relay today from junkyard and felt / heard the single click
Fuse 13 is still good, did not pop as well.
also got a lead on a p2e-426 he said was pulled from a running 96-98 hatch his buddy went b20. This ecu should work right?
