ObdII port not reading
I have a 1999 Honda Civic Ex with a b16 5mt swap. The ecu is a pr4-A11 with a obdI to obdII adapter.
The obd port on my car won’t give me codes but powers on the code reader. My questions are; Do I need a obdI code reader? And Should I look at other ecu’s for this car like a genuine 99 SI ecu?
Thank you
Thank you
OBD-1 ECU's do not communicate to the OBD-2 port. A PR4 ECU has no VTEC circuitry components installed, so unless these were added, VTEC will NOT work on the B16A. A '99 Civic Si ECU will run the engine properly and the OBD-2 port will function appropriately.
I’ve attaches some pictures of the problem
The crappy wiring done by previous owner
Wires to the ecu
They have ‘99 GSR written on the front of this but it’s not the right ecu for that car
