ABS light on...
Old Oct 5, 2020 | 02:54 AM
g4384063's Avatar
Default ABS light on...
Hello all,
After having my windshield replaced last week, my ABS light came on, when I got in my 96 Civic EX sedan and started driving. I’m assuming the windshield has nothing to do with this and is just a coincidence.
That said, the light continues to come on about 5-10 seconds after I start driving. How do I start to figure out what the issue is exactly with ABS?
I appreciate your feedback!
Old Oct 5, 2020 | 07:58 AM
muellersfan's Avatar
Default Re: ABS light on...
Jump the service connector; turn key to ON(II), and watch the cluster SRS blink the code.
Old Oct 5, 2020 | 09:06 AM
g4384063's Avatar
Thanks!
I get “turn key to ON(II),” but how do you “jump the service connector”?
Also, a bit confused about “watch the cluster SRS blink the code;” wouldn’t I be watching the ABS light blink the code?
Old Oct 5, 2020 | 11:38 AM
Originally Posted by g4384063
Thanks!
Same 2P connector above ECU used to pull CEL codes.
Haha...^Typo
Old Oct 6, 2020 | 06:24 AM
g4384063's Avatar
Thanks!
And excuse my ignorance, but I’m still a bit confused about what this means to do in order to “jump the service connector”? ☺️
Old Oct 6, 2020 | 06:31 AM
Please excuse the forum jargon.
Jump service connector = Use a paperclip or wire to short the two pins of the service connector.
Old Oct 7, 2020 | 06:54 AM
g4384063's Avatar
Ah, thanks!
I’ve been trying to find a video, but no luck yet, so if anyone has a link to one, please share.
Do the paper clips go into where you would normally plug in an OBD2 ready or a blue connector’s female end when unplugged?
Old Oct 7, 2020 | 07:02 AM
Have you succeeded in locating the service connector? The arrow is pointing to the green or blue rubber boot that protects the 2-pin service connector. The connector is free (not plugged into anything). Bridge the two connector pins with a paper clip.
Old Oct 7, 2020 | 02:50 PM
g4384063's Avatar
Thanks!
No, I haven’t located the service connector, yet; because I wasn’t exactly sure what I was looking for. That diagram pic should help, I appreciate it!
FWIW: I mentioned an unplugged blue connector’s female end, because I saw it on this video, but wasn’t sure if it applied to my 96 Civic...
Old Oct 7, 2020 | 08:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
This is a photo of the connector.
Old Oct 10, 2020 | 01:19 PM
g4384063's Avatar
Thanks, that’s very helpful!
Looks like this is it...?
Old Oct 10, 2020 | 01:40 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
No, that is the junction connector (20-Brown). Look more to the right, for a small blue connector.
Old Oct 10, 2020 | 03:35 PM
Remove the kick panel.
Old Oct 12, 2020 | 08:35 AM
g4384063's Avatar
Great, thanks!
I removed the kick panel and found my green rubber boot that protects the blue 2-pin service connector, which I unplugged and put a paper clip into the 2 female ends of.
When I turned the ignition to ON(II), I received the following sequences of long flashes followed by short flashes from the ABS light, which appeared to repeat over & over. Seems like a lot; how do I find out what these codes mean?
1-2
1-4
1-6
1-8
5-2
5-4
6-1
Old Oct 12, 2020 | 01:19 PM
Start by clearing all codes from the ABS computer. Then drive car to see which codes repeat, if any.
Old Oct 13, 2020 | 05:25 AM
g4384063's Avatar
Thanks!
I tried this technique, but the ABS light initially came on, when it went off, I took foot off the brake, but the ABS light never came back on, so I wasn’t able to complete the steps. Any other suggestions?
Old Oct 13, 2020 | 11:35 AM
Thanks!
https://m.youtube.com/watch?v=1S4O1AqIihM
If the ABS light does not return, then you are good to go.
Old Oct 13, 2020 | 01:52 PM
g4384063's Avatar
Unfortunately, it came on about 5-10 seconds after I started driving & stayed on, like it’s been doing, since it first came on recently.
Old Oct 13, 2020 | 01:59 PM
Pull the ABS code(s) again. You may now pull only one code, which would greatly focus your troubleshooting.
This diagram may help:
Old Oct 13, 2020 | 06:40 PM
g4384063's Avatar
Thanks!
I’ll pull codes again and see what I get.
As for DTC Erasure diagram, those were the steps I was attempting to complete, as per the video I posted.
That said, the very first step in video, which I attempted was to use a wire to connect pin 4 to pin 9 on the OBD2 connector. I’m not if that is the same as your diagram’s step 1, but it wasn’t inside passenger side kick panel.
Old Oct 13, 2020 | 06:50 PM
In your picture, pin 1 is jumped to pin 12 in the DLC connector. This would do nothing. In addition, DLC pins 4 and 9 are unused. Jump the service connector to clear the ABS codes.
Old Oct 14, 2020 | 05:25 AM
g4384063's Avatar
Thanks!
Just to clarify, that pic I posted was a screenshot from the video saying he was jumping pin 4 to pin 9; but I did attempt to jump the same pins.
That said...
1) Where is the DLC fuse location, so I can check to see if it’s blown?
2) Didn’t I already jump the service connector with the paper clip to get the sequence of codes listed above; and are you suggesting to just do the same, but this time as step 1 from the diagram you posted, then complete the rest of the steps, instead of just letting it pump out codes?
You jumped pin 8 to pin 13, which would blow the DLC fuse. And pins 4 and 9 in the data link connector are unused. Jump the service connector to clear the ABS codes.
Old Oct 14, 2020 | 05:31 AM
What I am saying is that you start over and follow the instructions in the diagram I posted to clear the ABS codes. I think you are saying the same thing below.
Didn’t I already jump the service connector with the paper clip to get the sequence of codes listed above; and you’re suggesting to just do the same, as step 1, but then complete the rest of the steps from the diagram you posted, instead of just letting it pump out codes?
Regarding the DLC fuse, I edited my post:
