Nut inside of the body broke off HELP (rear toe compensator link mount)
The nut for the rear compensator toe that is on the INSIDE of the body broke off... best way to get a new one in there ? here is a photo
the nut fell off in there!!
Re: Nut inside of the body broke off HELP (rear toe compensator link mount)
You have to cut a door into the room where the nut is. A cutting torch would be handy, but I was able to use a cutting wheel. To repair, you will have to use a washer or rebuild the window where the screw passes through.
