help on a unfamiliar honda!!!!!!
I am gettin rid of my del sol cause i got a kid now and i need something bigger!So I plan on gettin a cr-v and makin it b20/vtec/turbo.I know the only 5 speed cr-v is the awd one so can i still use my tranny?or is there a way to moddify the stock one and the rear diff?and who makes pistons for the b20, and rods.......what all will i have to do to do this?and what turbo kit to use....wouldnt i have to get a custom one built or a kit for the b20........someone please help!cause i dont kow **** about the b20 or cr-v's!
Most major mfg make pistons for the b20, rods are the same as an LS. Any LS turbo kit should come close to fitting, maybe even a B16. A CR-V, after all, is just an extended civic chassis. You will only be able to use the CR-V trans in that chassis because of the shifter design and awd layout, and I've been told that the rear diff and axles aren't up to much power, so you're gonna have to look into upgraded units.
SIReg9
Dec 15, 2002 04:51 AM
