I found a discrepancy between the ATTS technician's manual and the regular service manual regarding checking the ATTS ATF.
The ATTS info manual says to use the oil cooler banjo bolt to check the oil level (highlighted in blue).
The main service manual says to use a different bolt as the check (highlighted in yellow).
