Fuel feed removal at firewall
Old Sep 23, 2020 | 06:15 PM
csrucobo's Avatar
Default Fuel feed removal at firewall
How do I remove this bolt from the hard fuel feed line at the firewall? Trying to hook up an inline fuel filter to free up some space. Thanks in advance.
Old Sep 27, 2020 | 06:09 AM
Marcos Barrios's Avatar
Default Re: Fuel feed removal at firewall
you loosen the nut remove the hose then you cut the end of the line
that flared end
the 1/8th of a inch so that the nut can slide out
then you can attach your a-n fitting
hope this helped
Old Sep 28, 2020 | 07:43 AM
DaX's Avatar
DaX
Loved
Community Favorite
Use a flare nut wrench, sometimes called a line wrench.
Old Sep 28, 2020 | 08:29 PM
csrucobo's Avatar
Thanks gentleman. Used both your suggestions with success!
civic_66
Mar 6, 2009 07:00 AM
94DOHCDELSOL
Feb 4, 2005 11:00 AM
SIK IN DA HED
Mar 18, 2004 10:51 PM
