Obd-1 diagnostic plug trick doesnt work!?
My check engine light is on and today i cant get the paper clip trick to work to show the code/codes. It worked last time. Is there a fuse or anything for that? Thanks
Pop open the ECU and see if you see any obvious burn marks etc.
Typically when CEL is on solid no matter what I've understood it means the ECU has gone bad.
