2000 D16y7 crank no start - no spark possibly no fuel
I'm trying to figure out why I'm not getting any spark and when I got to the ICM it only has 3 wires. Everything I read says there should be 4. It has the top 3 wires but nothing on the one terminal sticking side ways.
In all the pictures I'm seeing the wire that should go there comes out of the sheath with the black/yellow wire but mine has only the one wire in the sheath.
It is a hitachi if that matters. Are they just differently wired?
ok I figured it out. I guess an OBD2B civic only uses 3 wires on the ICM and mine is correct. I replaced the coil with a used one and replaced the rotor and reinstalled the dizzy. Fired right up no problem.
hondatek614
12
Nov 20, 2021 10:45 AM
mr_fobster
Nov 13, 2008 09:10 PM
dr juice164
Jun 17, 2004 03:54 PM
