90 ef need a new ignition switch housing
Old Sep 11, 2020 | 01:18 AM
Closm85's Avatar
Default 90 ef need a new ignition switch housing
I'm in search of a new ignition switch housing . The one I have was broken off. Is there any difference between an auto and manual ? I have the manual 4 spd. The connectors are 2 plugs one with 5 spades and the other with 4. Any ideas? I don't wana spend almost 300 bucks on an autoparts one .
Old Sep 11, 2020 | 10:11 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: 90 ef need a new ignition switch housing
Are you talking about the lock cylinder on the column or are you talking about the electrical portion that bolts to the back of the switch?
My car is a 90 Sedan and was originally auto. I replaced all the lock cylinders (including the one on the column) from another EF that I found in the junk yard - I think it was a 5-speed 88-89. The auto lock cylinder will have the additional solenoid on it to prevent the key from being removed if the car is not in park. You can defeat/remove this though. The face of the lock cylinder from the 88-89 car does not sit flush with the hole in the plastic column cover - it is recessed about 1/4". It doesn't bother me and it functions the same, but be aware if you try pulling a lock cylinder from a junk yard.
Old Sep 11, 2020 | 11:53 AM
Closm85's Avatar
I'm talking about the lock housing that bolts to the column. I saw one for sale that came with the electrical part ,housing, and keys but it came off an AT . And I was wondering if it would work. But thanks man
fin781
Jun 16, 2011 08:30 AM
DelSolDon
Mar 4, 2007 05:59 PM
C8V6C
Mar 12, 2006 04:11 PM
mingchi69
Feb 5, 2004 04:32 PM
