Honda Del Sol Cusco 6 point roll cage mounting location pics
Old Sep 7, 2020 | 07:02 AM
b20vtecturbe's Avatar
Default Honda Del Sol Cusco 6 point roll cage mounting location pics
Hi this is my Del Sol I fitted my Cusco 6 point roll cage and before I got the cage I couldn’t find the mounting points pics wise from anywhere online so I just took the time out to take some pics for those that are looking or how and where the mounting points are. Note all interior pieces can be installed back into to car. The rear will have to be very detailed compartment wise to fit which I will do. Again this is just for those that want picture references as I will update as I continue the install as I want to customize my rear interior to make inter as oem looking or stock panels as possible
Old Sep 9, 2020 | 11:34 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Honda Del Sol Cusco 6 point roll cage mounting location pics
Any pics of it drilled out and fully bolted down?
what hardware did you use?
Old Sep 14, 2020 | 03:27 AM
I don’t but I will go ahead and do so the cage comes with Everything needed the mounting plates for the underside of car along with bolts as the cage sits but when I mount it which I’m just waiting on my sparco seat brackets to come so I make sure all is good before bolting cage down.
Old Sep 14, 2020 | 05:35 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Thank you for sharing, please do document the actual mounts both top side and underside with hardware etc. This will prove most helpful for those searching in the future.
I look forward to seeing the finished product.
Old Sep 15, 2020 | 06:47 AM
White_EG1's Avatar
Can you push the stock Del sol seat all the way back?
Nice cage but imo it looks like it takes away a good amount of cabin space especially for a sol
Old Sep 15, 2020 | 07:48 AM
tony_2018's Avatar
Fish Twig
It doesn't look like its obstructing the seat, might be able to still move it back a bit more. Like that last inch.
Old Sep 15, 2020 | 04:32 PM
BiggieBert's Avatar
Loved
Community Favorite
You will die.... eventually.. one day.. human.
Old Sep 15, 2020 | 05:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This is true for everyone regardless, Taxes and Death are two givens. Now if you are saying he's going to die because of a roll cage..... Well, that's conjecture.
Old Sep 20, 2020 | 06:56 PM
will do I also look for things like that and it never gets posted or so much information people want to know so I will be sure to document it for all to see
Old Sep 20, 2020 | 06:58 PM
from what I tried it seems that there is one last click sliding back wide that I couldn’t stock seat wise...I can’t say for any aftermarket seats. I am 6’4 and it was fine to me and I’m tall for sure you can let the seat back part back damn near all the way. Space is not bad any cage is going to take away space in that sense but I’m ok with it there is enough space
Old Sep 20, 2020 | 07:01 PM
I think maybe stock seat wise if that cover on the side is removed maybe it won’t be in the way and you can slide it that last click...I’m going to have aftermarket seats so i don’t think I’ll have to worry
Old Sep 20, 2020 | 07:02 PM
yes indeed that is true lol
Old Sep 20, 2020 | 07:04 PM
lol.....
Old Sep 20, 2020 | 07:17 PM
Hello all this is upgraded pics I’m posting after modifying my rear cabin interior I have only seen a few pics of this cage in Del sols but most of the time the rear interior is left out and gutted not sure if people didn’t think about the depth of attempting to get the interior in but I did this morning and I was stoked by how decent it came out...a few more touches I will do to it to clean up but overall I think it came out nice. I will update when I bolt in I just wanted to get everything mocked up and in place before bolting down and finalizing it.
Had to remove the lid from the compartment and notch out the corners needed.
A closer pic of the notch out.
Able to open lid enough to get my hand in and out to grab whatever so functional still
With all rear interior in besides roof piece that can go on no problem
Nice and snug but fit perfect
Old Sep 20, 2020 | 07:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Looks good! good job!
Old Sep 20, 2020 | 07:31 PM
Thanks...I appreciate it!!!!!
Old Sep 24, 2020 | 08:44 PM
TrackSol's Avatar
I haven't logged in to the forum in ages, but I did this time just to tell you thank you for sharing these pictures and details.
Old Oct 4, 2020 | 03:42 AM
that’s dope that you took the time out to log in and reply. I would have done the same. There are no reel in depth pics of something like this it’s either just showing front of cage or stripped out interior and no back shots. I just had to think outside the box and worked it out I believe this is the only pics and detailed info for the 6 point Cusco cage out there...oh and your welcome 🙏🏽
Old Dec 4, 2020 | 05:24 PM
Hyjnx's Avatar
does the top go on with no issues? I know i see them in pictures but I wasnt sure if putting it on or taking it off was as easy as factory?
Old Jan 1, 2021 | 07:44 PM
yeah top is not in the way of cage at all, it clears and to be honest it will probably have a little more clear once I bolt the cage down especially if I do it under the carpet but even bolted on top of carpet as it sits it clears...I would assume Cusco does use it track wise so they would have to make sure the top can go on the car and it does otherwise I wouldn’t see the cage selling at all...I wanted something bolt in that I could remove which is nice versus a weld in cage that would have to be cut up to get out if needed
Old Jan 2, 2021 | 07:55 AM
99stockcivic's Avatar
So what type of racing are you going to be doing?
Just curious.
Old Jan 23, 2021 | 04:52 AM
Just curious.
currently I’m still building up car, there was no plans to track it at all just build, show and drive every now and then as it won’t be a daily drive. Cage strengthens car especially with the top off so at the very least it’s to strengthen the chassis while driving
Old Mar 16, 2021 | 03:18 AM
I’m currently doing a rhd conversion on my de Sol you can follow the build here as I will be posting the build but you can also follow me on you tube @ corey moto or Instagram @jdmek100 for build pics as well
Old Jul 6, 2021 | 02:21 PM
Narayanan's Avatar
Hey could you let me know where you got your cage from? Just started my del sol build.
portenio78
Feb 28, 2011 09:29 PM
Jedi_Sol
Mar 19, 2005 09:32 PM
SICKSOLSI
Aug 28, 2004 06:52 AM
MiX
Jul 15, 2004 10:13 PM
Pengo
May 21, 2002 08:53 PM
