can you run stg 1 cams with stock valve springs
Old Sep 3, 2020 | 03:12 PM
purposebuilt's Avatar
Default can you run stg 1 cams with stock valve springs
hi i was just woundering if you can run stock gsr valve springs with a stg 1 cam(like sk2,blox) if im only going to 8200rpm. I know you can with ctr cams and a stg one cams not that much bigger
Old Sep 4, 2020 | 03:12 PM
Sic_DA_Nine's Avatar
Default Re: can you run stg 1 cams with stock valve springs
google is your friend.
google the manufacture of the cam you are interested in running, and manufacturer website should provide information on what is recommended, and/or what is required
sk2:
Tuner Stage 1 Camshaft - B VTEC
Must use Skunk2 Racing Alpha Valve Spring and Retainer (P/N 344-05-1300) or Pro Series Valve Springs (P/N 311-05-5350) and Pro Series Retainers (P/N 308-05-0300).
blox:
Tuner Series Type-A Camshafts (B-series DOHC VTEC)
Upgraded valvetrain is not necessary, but is always recommended.
Old Sep 4, 2020 | 08:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I would install dual valve springs on ANY camshaft upgrade in a "B" series engine.
Old Sep 6, 2020 | 08:51 AM
TheShodan's Avatar
Moderator
You don't have to, but know the age of your valvetrain when decided.
JHipps
Oct 13, 2013 08:37 AM
bsmith100
Jun 12, 2008 04:42 PM
touchmyHONDA
12
Feb 2, 2008 07:08 PM
b18 hatch mike
Jul 8, 2007 11:56 AM
johnE ej
Mar 30, 2004 02:09 PM
