94 Honda Accord lx
Old Aug 30, 2020 | 08:40 AM
Karl Graves's Avatar
Default 94 Honda Accord lx
Dose anyone know we're maf sensor is
On 92 Honda Accord
Old Aug 30, 2020 | 08:48 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 94 Honda Accord lx
A '92 doesn't have a MAF sensor.
Old Aug 30, 2020 | 09:35 AM
99stockcivic's Avatar
I believe you have a MAP (Manifold Air Pressure) sensor and an IAT (Intake Air Temp) sensor, not a MAF.
I think this shows it to you although probably different year car.
Old Aug 30, 2020 | 10:52 AM
Why when I start my car 92 Honda Accord lx the engine revs up and down replaced throttle body and cleaned oxygen sensor
Old Aug 30, 2020 | 06:26 PM
Are you saying it's not idling correctly? I would think it's the IAC (idle air control).
I have heard some people say it can also happen (although I'm not sure why) if you have low coolant, so check that just in case.
Old Sep 1, 2020 | 06:52 PM
Alanissa2's Avatar
check vaccum hoses ,or iac valve keep ur car on an take off ur iac valve plug if ur idle keep actin the same way then u have a vaccum leak but if the idle calms down then ur iac valve is bad check every vaccum hoses
Old Sep 6, 2020 | 10:51 AM
Default 92 Honda Accord lx
Dose anybody know if there is a idle air sensors on 92 Honda Accord if we're
Old Sep 6, 2020 | 10:53 AM
Default 92Honda Accord lx
My 92 Honda Accord keeps revving up and down replaced throttle position sensor and cleaned oxygen sensor don't know what's going on yes has water
Old Sep 6, 2020 | 05:12 PM
MAD_MIKE's Avatar
MM Gruppe B
If your idle is hunting, verify your IACV and FITV are operating correctly.
Check out the HOW TO in the FAQ link at the top of the forum.
This generation of Accord is a Speed Density system. There are no MAF or VAF to directly measure air mass.
Old Nov 9, 2020 | 07:36 AM
My 92 the idle keep going up and down like revs then drops then revs any ideas I've changed the ignition control module but stumped any ideas
Old Nov 9, 2020 | 07:59 AM
hondamark35's Avatar
Default Re: 92Honda Accord lx
My 92 the idle keep going up and down like revs then drops then revs any ideas [?]
best guess- vacuum leak. this is a manual or automatic?
...I've changed the ignition control module...
Why?
Old Nov 9, 2020 | 08:26 AM
I'm with hondamark35, I'd first check for vacuum leak. Go around and start examing and pinching hoses, look to see if any are cracked or fallen off. Pinching them is to close the possible vacuum and see if anything changes.
Old Nov 9, 2020 | 09:13 AM
It's a automatic
Old Nov 10, 2020 | 07:21 AM
My car the idle goes up and down there is three hoses on top of the motor that goes to control box I take one off it don't rev as much but it still revs put back on goes back up what could it be
Old Nov 10, 2020 | 11:58 AM
Please help can anybody help I'm trying to fix idle problem it keeps trying up and down please help also dose anyone know how to make a home built smoke machine so I can hook up to car and how to hook it up
Old Nov 10, 2020 | 02:06 PM
2001GSRSC's Avatar
5 Year Member
If you let the idle problem continue..perhaps it will become a smoke machine.. 2 birds with one stone , eh?
Amazing amount of information you've relayed to me. Sherlock Holmes couldnt find a lead to go on.
The classic Bond car smoke screen can be done, by introducing transmission fluid in to the combustion process. Huge white clouds.
Old Nov 10, 2020 | 02:21 PM
2001GSRSC's Avatar
5 Year Member
what could it be
True love.
Sounds like your making a vacuum leak when you pull the hose off uncapped.
Old Nov 10, 2020 | 03:03 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
All your multiple separate threads regarding the same issue have been merged.
Please do not make separate new threads regarding the same issue.
76 camaro car
Nov 21, 2015 09:46 AM
1SIKZ31
Jan 4, 2007 05:11 PM
