Rear lower control arms
Old Aug 25, 2020 | 08:31 AM
b1rcyu76's Avatar
Default Rear lower control arms
I was wondering where I can find the bolt sizes for the lower control arms and trailing arms on my ek hatchback civic, I had to cut some out and need to replace them
Old Aug 25, 2020 | 10:22 AM
tony_2018's Avatar
Fish Twig
Default Re: Rear lower control arms
online parts diagrams have em.
Old Aug 25, 2020 | 12:12 PM
Relic1's Avatar
rear lower control arm bolts --> 90173-SR3-003 -- Bolt, Arm (LOWER) (10X80)
taken from here... https://www.hondapartsnow.com/parts-...lower_arm.html
Old Aug 25, 2020 | 09:54 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
What that doesn't tell you is the thread pitch (I think it's 1.25) and the metric grade of the bolt (I think it's at least a 10.9 if not a 12.9).
So if I'm accurate it would be M10x1.25 at 80mm length, partial threaded 10.9 or 12.9 grade.
Old Aug 26, 2020 | 09:03 AM
tony_2018's Avatar
Fish Twig
can be found, if you have the right tool, with the broken bolt.
Old Aug 27, 2020 | 09:41 AM
chrysler kid's Avatar
or that it's the same size as the other 2 volts that hold the strut to the arm and hold the arm to the knuckle
Old Aug 27, 2020 | 09:57 AM
tony_2018's Avatar
Fish Twig
no, I meant getting the thread size.
Old Aug 27, 2020 | 08:23 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you didn't know the other two are basically the same bolt with only minor differences and depending on where the bolt broke, you may not be able to determine thread pitch, and only experience will tell you steel class.
I believe the bolt in question is a partially threaded bolt and if it's seized where it breaks above the threads, there is no threads to measure pitch.
Rickmirelez
Honda Civic (2006 - 2015)
Dec 13, 2010 05:46 AM
