Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
No crank no start after CAM replacement.
Old Aug 21, 2020 | 04:28 PM
Aaron Edeus's Avatar
Default No crank no start after CAM replacement.
As title states, getting no crank/start after CAM sensor replacement. Done on a buddies car because of 631 and 632 codes.
Hooked battery back up after install. Hazard lights came on. When turning the key, the car starts intermittent beeping along with an alternating flash between the park indicator light and the lights for the dash needles. Car continues to beep after removing the keys.
I can hear relays clicking in the fuse box. Going to replace the 80A battery fuse and ignition fuse as well.
I’m at a loss if the fuse doesn’t work in the morning. Called multiple Honda shops and no help from them either.
also, valve cover gasket and previous sensor were newer. Hopefully for him it’s not an actually camshaft issue. Looked like a cheap sensor though. Hoping genuine Honda will fix it.
Any ideas?
91sedan_kid
Jan 19, 2025 09:13 PM
VTEC_Viking
Jan 7, 2017 04:54 PM
Lastman
11
Sep 4, 2015 04:20 PM
maxpowers125
Jun 14, 2008 09:53 AM
