Jdm b16a swap won’t start
Old Aug 19, 2020 | 11:28 AM
Wolfeman2001's Avatar
Default Jdm b16a swap won’t start
I have swapped a 89 JDM b16a obd0 into my 97 ex civic. The previous owner before me had rebuilt the internals of the motor but never started it after the rebuilt. Eventually it was sold to me, I changed everything to obd2 on the outside of the motor and am running a obd1 p30 ecu. After everything has been hooked up I am able to crank the motor but cannot get it to start. If someone could help I’d appreciate
Old Aug 19, 2020 | 11:55 AM
tony_2018's Avatar
Fish Twig
Default Re: Jdm b16a swap won’t start
check for fuel and spark?
Old Aug 19, 2020 | 12:06 PM
I have changed the fuel pump and filter along with the main replay and injectors. I have fuel to the fuel rail but nothing coming out of the injectors before or after I changed everything.
I just got new spark plugs and each plug wire has spark to them so I can rule out that works.
Old Aug 19, 2020 | 02:47 PM
egsleepercivic's Avatar
did you install a resistor box for the obd0 injectors ?
Old Aug 19, 2020 | 07:30 PM
I changed the injectors to obd2 99si along with the whole intake manifold l. Do I have to change the register box still?
Old Aug 19, 2020 | 07:39 PM
wunfstgsr's Avatar
Loved
Community Favorite
Are you using a OBD2A to OBD1 ECU conversion harness?
Old Aug 19, 2020 | 08:06 PM
no not for the obd2 injectors
Old Aug 19, 2020 | 08:36 PM
Yes I am using a jumper harness it’s obd2a to obd1. I did by it for like $20 on eBay. I also using a wire harness out of an 96 auto ex civic.
Old Aug 19, 2020 | 08:43 PM
this might be a problem because the manuals have a safety switch on the clutch pedal
The autos have something that only lets it start in park and neutral
you should be able to find a thread on hear on how to modify it
aidenbloomfield
Aug 18, 2013 02:17 PM
silverbullet5410
May 12, 2012 06:36 AM
enjoi1104
Apr 26, 2009 05:18 PM
vu337
20
Nov 15, 2005 12:37 PM
dahveed
Jan 27, 2004 08:15 AM
