Automatic transmission...
Old Nov 15, 2002 | 09:31 PM
Art Vandeleigh's Avatar
Default Automatic transmission...
hey all. well its about that time to change the tranny oil from my 01 accord, but i have never worked on a auto tranny before. i have tried the search, but nothing really came up to help. how is it different then my manual tranny?? where is the drain and refill bolt. thanks all!!! oh and what are the tq specs. i dont have my helms yet for the accord. thanks again!!
Old Nov 15, 2002 | 09:33 PM
Accord94DX's Avatar
Default Re: Automatic transmission... (Art Vandeleigh)
you easily spot the tranny drain bolt when you are under the car, on your accord it might actually be labled "TRANS" or something to that sort. Fill through the dipstick hole.
Old Nov 15, 2002 | 09:41 PM
Default Re: Automatic transmission... (Accord94DX)
WOW, fill throught the dipstick hole you say?? thats weird...there is no refill bolt?? hhhrrrmmmmmmm. thanks...tq specs??
Old Nov 15, 2002 | 09:51 PM
Accord94DX's Avatar
should note the drain plug will be a 3/8 square female bolt. Just use a 3/8 drive extension to loosen it. 38ft/lbs is what the helms manual tells me to tighten it to.
Old Nov 15, 2002 | 09:54 PM
scrubachu's Avatar
dont listen to any of them, they are all wrong. lol. just because they have 3000 posts doesnt mean they know everything. oh wait, it does. crap
Old Nov 15, 2002 | 09:58 PM
Accord94DX's Avatar
Default Re: Automatic transmission... (scrubachu)
6400 posts n00b!!!!
Old Nov 15, 2002 | 10:01 PM
thanks man!!! appreciate it!!
Old Nov 15, 2002 | 10:11 PM
Accord94DX's Avatar
no problem
Old Nov 15, 2002 | 10:34 PM
SOHCArchangel's Avatar
*sn0rt, NARF*
Old Nov 16, 2002 | 01:21 AM
iam7head's Avatar
Default Re: Automatic transmission... (SOHCArchangel)
how often you guy change tranny oil?
Old Nov 16, 2002 | 01:30 AM
iam7head's Avatar
Default Re: Automatic transmission... (iam7head)
Criminal daddy say "tranny cooler is your friend"
Old Nov 16, 2002 | 07:31 AM
Accord94DX's Avatar
15-30k
Desslok's Avatar
When I changed mine, there was gunk all over the magnetic drain plug, so I cleaned it off changed the fluid, drove it 2 days, and then changed it again and cleaned off more of that gunk on the drain plug.
Old Nov 17, 2002 | 09:58 PM
briq4's Avatar
Default Re: Automatic transmission... (sp)
OK I know this is going to sound crazy but I change my mom's tranny oil for her and I do it every other oil change. Why? Becuase when you "change" the fluid you are only changing a small amount of the whole. The total is I think around 7 quarts or so and you only drain out about 3. Hence why I think it should be changed more often, plus why let that old burnt smelling fluid keep flowing around? Cheaper to change the fluid than to rebulid the tranny. And I think we all know that Honda Transmissions are a bit on the touchy side.
As for a filler bolt, the 98 V-6 has a filler bolt on top of the tranny, it's towards the driver side of the car towards the back of the tranny, it had a red mark across it. Guess that was from the factory.
Old Nov 17, 2002 | 11:14 PM
iam7head's Avatar
Default Re: Automatic transmission... (briq4)
this moron cant find the tranny oil filter.
how big is it? same as a motor oil filter??
and anyone know where is it for 6th gen accord 4cyl?
[Modified by iam7head, 8:14 AM 11/18/2002]
Old Nov 17, 2002 | 11:19 PM
briq4's Avatar
Transmission filter is an integral part of the transmission and is considered a "life of the vehicle" item. If you want to change it you will have to crack open the tranny and find it.
Well at least that's how it is on a V-6.
[Modified by briq4, 3:20 AM 11/18/2002]
Old Nov 17, 2002 | 11:21 PM
chad's Avatar
Moderator
i believe it is in the tranny.....
Old Nov 17, 2002 | 11:29 PM
Accord94DX's Avatar
in the tranny.
Old Nov 18, 2002 | 05:55 AM
KTeller8's Avatar
in the tranny.
KDoGx504
Oct 7, 2005 01:54 PM
CR-Vision99
Jun 25, 2005 04:13 PM
2KCivicDude
Jul 24, 2004 06:50 AM
ModlesSI
Sep 17, 2002 01:22 AM
