2005 Accord cranks, fuel press, injectors not firing, only one spark per crank
Car cranks and has fuel to the injector rail but the plug only fires once per crank no matter how long you crank. This car hit a deer but only front end damage. Bought a 2006 accord so i could use this car for parts. The 2006 car i swaped the radio from this car because the a/c did not work. Both cars worked as far as engine running. Backed this car up and parked for aprox 1 1/2 years. Entered the correct radio code and radio works. Removed the injector rail with injectors pointed up to see if they put any fuel out, nothing.put a light on plug wire and only onespark per crank. Seems that something is causing the compter to stop the fuel and the plugs to fire only once. I would like to get this running so i could help out a low income person with a car. The car has around 300,000 miles on it but always ran like a dream before Mr deer got in the way. Drove car many miles after the thunk. I think I'm missing something simple. Please help if you can. I don't want to spend a lot of time troubleshooting. Thanks!!
chadwick16
Sep 27, 2005 03:33 PM
12thstreetjunkman
Nov 6, 2004 06:09 AM
