Wiring issues
Old Aug 13, 2020 | 02:39 PM
1320vickers's Avatar
Default Wiring issues
I have a 91crx si and the main harness was a mess when I got it recently I was cutting wires i didn’t need anymore like the heater motor etc now the ecu doesn’t seem to be getting power I’ve checked all the grounds I know of a m not sure which wire feeds the ecu power
Old Aug 13, 2020 | 06:34 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Wiring issues
Do you have a copy of the factory service manual (FSM)? They can easily be found online by googling around. There are good wiring diagrams in the FSM. Get a copy and get out your multi-meter. Happy hunting.
Old Aug 14, 2020 | 06:21 AM
jlicrx's Avatar
power for the ECU comes from the Main Relay
Old Aug 14, 2020 | 07:16 AM
I have a new relay that I keep switching between I was trying to find the tps wire when I moved the harness close to the ecu it would flicker. I have the wrap completely off the harness and don’t see any broken wires
Old Aug 14, 2020 | 09:40 AM
DaX's Avatar
DaX
Loved
Community Favorite
It could be a worn out harness terminal that isn't making good connection with the ECU pins.
Old Aug 14, 2020 | 10:01 AM
I bought a cheap adapter off eBay I was kinda thot that may be it I don’t understand the manual very well I can’t tell which wires directly affect the ecu power
Old Aug 15, 2020 | 03:53 PM
Is there anyway to check if a ecu is bad by looking at it. Like if it’s not burnt or the the lines are still in contact it should be good rite
Old Aug 17, 2020 | 07:46 AM
Does anyone know if a civic main harness would work
Old Aug 17, 2020 | 11:44 AM
This is driving me crazy all wires that should be hot have 12 volts on plug a. All grounds are grounded on plug a there shouldn’t be any other wires that would keep it from working
Old Aug 17, 2020 | 12:18 PM
DaX's Avatar
DaX
Loved
Community Favorite
I assume you're checking the pins in the connector with the ECU disconnected? To test my theory of having worn out harness terminals, you can remove the ECU cover, plug the connectors in, then CAREFULLY probe the back of the pin inside the ECU. If the wire in the plug has power when disconnected from the ECU but you're not getting it on the pin inside the ECU, the terminal in the plug is worn out and not making contact with the ECU pin.
Old Aug 17, 2020 | 01:32 PM
jlicrx's Avatar
(2) yellow with black stripe wires from main relay to ECU at pins A13 and A15
Old Aug 17, 2020 | 03:24 PM
Default FRe: Wiring issues
No luck I got 12v on both pins in the ecu can a ecu be bad without showing any Visible signs
Old Aug 17, 2020 | 03:27 PM
The s300 says the ignition is off even though I know it’s on I hear the injectors click and the main relay clicks
Old Aug 17, 2020 | 03:54 PM
DaX's Avatar
DaX
Loved
Community Favorite
It is possible for the ECU to be bad with no visible signs. However, if I understand correctly that it was running fine before you started cutting out wires, it's unlikely that the ECU would be the problem. Do you have a spare ECU you can try in the car, or do you have another car you could try the ECU in?
Old Aug 17, 2020 | 04:19 PM
I wish I did unfortunately I’m going to have buy one just to see if that’s the problem if that doesn’t work I’ll just buy another harness
existanzcivicb20
Dec 25, 2013 03:41 AM
em1_sir
K Series
28
Oct 30, 2011 06:56 PM
em1_sir
46
Oct 9, 2011 12:27 PM
em1_sir
Oct 5, 2011 05:01 PM
JOHN WAYNE
Jul 12, 2002 08:52 AM
