So I bought some detent springs for my b series trans, when i took out the two bolts with springs and the ball bearing i was expecting it to fall out but instead it's stuck inside the bolt with the spring. Any ideas of removing it or is there a place where i can get new bolts and bearings.
You can get new ***** or springs from your local Honda dealership... there should be a small hole in the detent bolt that you can use a pick to push the ball out.
Thanks, I tried getting something thin enough to fit in the hole. Only thing small enough was a paperclip, didn't budget though. Are they the same price to buy locally or cheaper online on genuine honda parts website?
