2000 Accord EX engine harness blue with black stripe wire
Found a dangling wire on 2000 Accord EX engine harness. 2 dr coupe with A/T. Wire is Located on passenger side. Wire is blue with black stripe, no connector on end of wire. Car has no cel codes. I can't find any sensors missing a wire.
Re: 2000 Accord EX engine harness blue with black stripe wire
QUOTE=tech8;52235994]Probably the wire for the 2nd Clutch Pressure Switch
[/QUOTE]
I bet you're correct. Problem is, 1] There is no sensor at that location (see picture), and 2) the bare end of wire is 8 inches from location on your picture of sensor. Someone maybe cut wire. Distributor removed
