B16a ek swap won’t start
I have a JDM b16a swap into my 97ex civic. The motor cranks but I cannot get it to start. When I started inspecting more I notice it was not getting fuel. I put in a new fuel pump and assembly along with a new main relay and a fuel filter but I still can’t get the fuel pump to prime when I turn to the key. For the time being we jumped the fuel pump with a battery and got It to prime and get fuel to the fuel rail. When I tried to crank the motor again the injectors where not working. After this I looked at my ECU and obd1 jumper harness and everything was plugged in fine. I even tried to do the obd1 paper clip in plug engine code check but nothing would flash on my gauges all there is a lit up check engine light. I have no idea why any of the fuel systems working at this point. So I’d someone could help id really appreciate
Ok first when I turn the key to on, I don’t hear the fuel pump and the engine light stays on constantly it does not flash or go off.
Second I did have to get a new wire harness because all the connections where cracked or broken on the original. My old one was for my 97 ex civic and the new one I bought came out of a 96 ex civic auto.
screen_name
15
Apr 17, 2005 09:19 PM
phreakywhiteboy
Mar 23, 2005 07:19 PM
