97 civic lx pilot bearing
Old Aug 2, 2020 | 10:33 PM
kyre white's Avatar
Default 97 civic lx pilot bearing
Hey so I’ve been trying to do the tranny swap and I’ve ran into a problem. No matter what I try I can’t get this bearing in the crank. I tried freezing it greasing it and tapping. Any ideas?
Old Aug 3, 2020 | 09:56 PM
chrysler kid's Avatar
Default Re: 97 civic lx pilot bearing
Rent a pilot bearing removal tool from autozone
Old Aug 4, 2020 | 07:57 AM
hondamark35's Avatar
is the number on the bearing "6002..."? the OD should be 32mm.
check for and remove burrs on the flywheel bore edge. it should be a snug fit, but shouldn't require a hydraulic press or anything.
Old Aug 4, 2020 | 08:26 AM
tony_2018's Avatar
Fish Twig
Clean up the crank, make sure you have the correct bearing.
lalib
12
Jan 13, 2015 05:43 AM
killacam661
Jan 13, 2010 05:20 PM
RichieBarber
May 5, 2004 06:27 PM
TurboSam
Nov 24, 2003 11:42 PM
