First time welding [question]
Old Jul 30, 2020 | 07:42 AM
Gemene's Avatar
Default First time welding [question]
So I bought a MIG welder , and I’m going to be installing and welding a 2008 civic radiator support on. ive looked and can’t find any info on it so I have some questions I wanted to ask .such as which welding material should I use , which shielding gas I currently have 75 argon 25 co2 would this work? And what settings would be best for this job?
Old Jul 31, 2020 | 06:40 AM
Ryanthegreat1's Avatar
Default Re: First time welding [question]
Mild steel, er70 wire in 0.023" diameter, gas is fine for the application. Look at your welder for a settings chart. Should be something for 20 gauge steel. Adjust up and down from there until you find something that works.
If you are filling in drilled out spot welds I would recommend a copper welding spoon to reduce burn through and help get those holes filled quickly.
Old Jul 31, 2020 | 10:46 AM
Gemene's Avatar
Awesome thanks man
Old Aug 2, 2020 | 05:54 AM
TDFbound's Avatar
5 Year Member
Loved
If you can find some scrap of similar thickness, it would help to play around with it to tune the settings. Make sure you have a good ground, don't weld out in the wind if you can help it, even a fan too close can sometimes blow the gas away and your weld will look like swiss cheese.
jdmISmyGOD
Welding / Fabrication
Mar 18, 2011 10:43 AM
777
Jun 19, 2007 01:10 PM
777
Jun 19, 2007 12:59 PM
