Modifying Old School: Can DSM Injectors in an F23A1 engine? If so, where do I start?
What’s up y’all, I’m planning on adding a turbo kit to my Accord, but I’m struggling to find the right performance fuel injectors (most likely 440CC because I’m only planning on running 7 psi). The ones I see on eBay and other places are for the F23A5 non-VTEC. And the ones I see for my car are $70 ones from Chinese companies that I don’t know if I should trust.
I have a 98 LX 5-Speed, which is the F23A1. Would those injectors work for this too? Or could you guys recommend some?
I think you are ok. I used ebay to look, such as here:
https://www.ebay.com/itm/4PCS-NEW-OE....c100008.m2219
And simply put in the year car the engine came from, and it seems they are the same. This link even has the adapters to fit it if not a direct plug in.
Do DSM Eclipse 450cc fit directly on this engine? And if so, would I need to buy a resistor box? I'm planning on putting in a turbo kit and push 7 psi to be safe.
Fewer and fewer people go this route, due to the other options available that are direct plug in. You spend more money, but you save a lot of time, and deal with fewer extra parts
Brand new, smaller size injectors can be had for dirt cheap. No need to use those old injectors.
I haven’t ordered any injectors as of yet. Was looking to see if I could find some brands people recommend. I saw a lot of people using DSM 450CC injectors, and I found them on eBay, so I wanted to see if those were hard to put in.
Depending upon what you're trying to do, these will only go for about 230whp-300whp at maximum duty cycle, (which is what you don't want to be at ever) . So, again. look to your goals and when in doubt, Buy once, cry once, and get the right equipment. Don't just go for "the cheap deal". It will always cost you more later.
