random shutting off and random misfire
ok sorry if this has been posted before but i am new to this forum.
98 accord auto, hit has a random misfire, and with not start sometimes, and will shut off randomly. i have done new plugs, wires, cap, rotor, igniter inside the distributor and the coil. also i notice the dash does not light up or turns off when it will not start. i have been told crank pos censor, and main relay and fuel pump. the pump tested good and has no problems and builds pressure, screen is very clean and no dirt in the gas tank, it is super clean. where is the main relay located and what am i missing? i am out of ideas and this was a very good running car.
need help
need help
The dash not lighting up is a clue that it may be a faulty ignition switch. The link also has info. on the main relay.
How to replace the ignition switch or troubleshoot (Honda, Acura)
The main relay is used to operate the fuel pump and supplies power to the fuel injectors (there are actually two relays inside the one main relay). They are one in the same.
Btw: Is that a transposition error in your signature (89 vs 98)?
NOTUNINGNONADA
10
Nov 21, 2017 04:11 AM
james myers
Engine Management and Tuning
Jan 19, 2017 12:08 PM
nova1370
Apr 30, 2012 07:07 AM
bmxmacdaddy
14
Jan 8, 2009 08:04 PM
