Yep, another ruckus no start issue
I have a 2015 ruckus. It’s modded a bit. Just the basics. I did not do them. I bought it as is. I have a brand new battery, new blue starter relay, new fuses, new fuel pump, new fuel filter, cleaned the carb and jets, adjusted the valve shims. It ran great. A little boggy around 20 mph. But it goes 38 no problem. The electric start worked just fine until a few days ago. Kick start works with minimal effort. Now the electric start just clicks. I checked the wires and connections. All appear to be good. Tail lights light up head lights turn on when it’s running. When I hit the electric start button, the blue relay does one click. A click you can feel. As I mentioned, I bought a new one. With new fuses and a new battery that has a charge over 13 volts.
Any suggestions? I’m not sure what else would cause the one single click in the starter relay and I can not find any info.
thanks in advance!
thanks in advance!
Sexy_Chantal
Oct 28, 2004 04:18 PM
UNDER PRESSURE
Jun 21, 2004 08:47 AM
