Civic 1995 hatchback fuel pump or ecu?
Old Jul 15, 2020 | 05:05 PM
Timothy Yhtomit's Avatar
Default Civic 1995 hatchback fuel pump or ecu?
Got a 95 honda civic with a GSR. Car was not starting on it's own, had to hit the starter. Right when I unhooked the main relay and swapped it for a new one, the fuel pump started not to work. Had a few main relay laying around and swapped all those but still not working also. I swapped the ecu with a LS ecu to just see if it would start, the fuel pump primed and car started fine. Ecu was working good before I unplugged the main relay just had to hit the starter to start the car. After the main relay was swapped the gsr ecu the check engine light stayed on in the the II position but with the LS ecu it did not stay on. Don't have another car to test the ecu on. Could it be the ecu? check the 24 slot fuse and it was still good.
Old Jul 15, 2020 | 05:11 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Civic 1995 hatchback fuel pump or ecu?
Open the back of ECU cover it may have burnt capacitors give it a good inspection.
oresama
31
Jan 19, 2025 10:47 PM
Bushybob94
Jun 5, 2018 11:40 AM
Rawnee7
Jun 21, 2014 08:28 PM
Nick7
May 14, 2011 08:57 AM
hybridb18
Apr 9, 2004 04:09 AM
