Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Replacing brake pads, adjuster?
Old Jul 15, 2020 | 12:06 PM
miked2's Avatar
Default Replacing brake pads, adjuster?
Hi all, quick question about replacing the brakes
I've tried before quick but ended up just taking it to the shop but they seem to take forever and want to try again as new pads are needed. Getting new pads in is easy enough but when I put it all back together the lever still needed pulled quite a bit, to the point of the adjusting nut needing to be in about 3/4 inch, which doesn't seem right with brand new pads. When it comes back from the shop the lever is tight and the nut is all the way to the end like you would expect with new pads.
Is there another adjuster or something that I'm missing that you move/reposition when doing the brakes?
Thanks,
mickey513
Nov 16, 2018 03:56 PM
heyimrchills
Nov 4, 2009 11:48 AM
MrDomino
May 16, 2008 08:42 AM
ebonyrolla7
Dec 19, 2005 03:56 PM
Vampyre
Mar 26, 2003 08:11 AM
