AC does not blow cold at idle.
Old Jul 13, 2020 | 12:57 PM
dgdarien's Avatar
Default AC does not blow cold at idle.
I have a 2000 Civic. I replaced the compressor, discharge line/tube that was leaking, replaced the receiver drier, replaced schrader valves and caps, added in the recommended amount of PAG oil, put the system under vacuum and noticed no leaks, and recharged with the recommended 22 ounces of R134a.
AC compressor kicks in and fan is running but blows WARM at idle, ac blows cold when car is moving or if I increase idle RPM. Is it possible the A/C fan is not spinning as fast as it should; is there any way to diagnose or service something like that, save replacing it.
Old Jul 13, 2020 | 02:34 PM
99stockcivic's Avatar
Default Re: AC does not blow cold at idle.
When you filled the R134A, did you have a gauge so you can see if you actually have the right amount in there? I've never just put the amount recommended, always used a gauge until it was in the green zone with the temperature adjustment slider on it (air con will read differently at say 40 degrees vs 100 degrees).
you might be just a little low or high.
Old Jul 13, 2020 | 02:45 PM
dgdarien's Avatar
Yeah I have a ac manifold gauge set and I added 22 ounces by weight.
Old Jul 13, 2020 | 05:28 PM
muellersfan's Avatar
Did the compressor fail? If so, you must also replace the condenser, evaporator, and expansion valve. You also need to flush the A/C lines.
Old Jul 14, 2020 | 12:55 PM
dgdarien's Avatar
The condenser fan PULLS air from the front towards the rear, that's normal, yeah?
Old Jul 14, 2020 | 01:55 PM
Correct. It should.
Old Jul 14, 2020 | 06:53 PM
chrysler kid's Avatar
Yes it is possible that the AC condenser fan can fail. You can replace the relay to see if that changes anything as the relay can become weakened over time
You also want to monitor the high side ac pressure to see if the temperature of the condenser is affecting pressures in the system. It will also help to watch the pressure to see if the AC pressure switch is working correctly.
Old Jul 15, 2020 | 02:51 PM
dgdarien's Avatar
I'm still trying to figure out why the performance is related to RPM. Is it possible the cheap replacement compressor I bought is weak?
Old Jul 15, 2020 | 03:06 PM
Study the A/C circuit diagram for your car. Do you know why the compressor clutch relay is controlled by the ECU?
Old Jul 16, 2020 | 10:05 AM
dgdarien's Avatar
I'm not sure what you're trying to show me with that diagram, I don't totally understand it.
The compressor did fail but I only replaced the compressor, condenser and drier, because I was told that if there were pieces in the system, it would have been collected and stuck in those components.
Old Jul 16, 2020 | 11:13 AM
The evaporator and condenser accumulate most of the failing compressor's metal debris due to having the highest internal surface areas. And you should never re-use the expansion valve after a compressor failure. I hope you get lucky, but only time will tell.
The ECU is integrated into the A/C circuit because it has an important function (idle speed control) in ensuring that the A/C system runs smoothly and efficiently.
Old Jul 16, 2020 | 03:45 PM
dgdarien's Avatar
Well it's bearable for the meantime, since I really don't feel like opening the system again. But I suppose if I ever get eager enough to continue the repairs; replacing the evaporator and expansion valve should solve the issue?
Old Jul 16, 2020 | 04:00 PM
I don't have access to your car, so I can't diagnose what ails it. What I can do is try to point you in a direction based on what information you have shared.
For example,
1) Describe the engine behavior when the A/C blows warm at idle.
2) Performance test your A/C system (detailed in service manual) and plot the results on chart provided there.
Old Jul 16, 2020 | 04:04 PM
You don't need the station shown in the diagram. A manifold gauge set is sufficient.
Old Jul 16, 2020 | 04:13 PM
Old Jul 16, 2020 | 04:17 PM
Are you absolutely certain that the condenser fan runs and compressor clutch stays engaged when the A/C blows warm with the engine idling?
Old Jul 16, 2020 | 07:41 PM
dgdarien's Avatar
I did that test just now while ambient temperatures were cool; AC has no issue blowing cold air during idle. It seems as though it struggles when ambient temperatures are warm/hot and at idle. Condenser fan and compressor clutch engaged is confirmed.
It seems as though the High side pressure is low and the low side pressure is high.
I will attempt to do the test again when ambient temperatures are warm during the day.
Old Jul 16, 2020 | 08:00 PM
Did you follow these instructions? If so, the compressor may be faulty.
Old Jul 17, 2020 | 08:10 AM
tony_2018's Avatar
Fish Twig
There we go, posting FSM pages like a boss
Old Jul 18, 2020 | 04:38 PM
If the low side pressure is high while the high side pressure is low, your expansion valve is not functioning properly
This can be from contamination from debris like leaves and grime or a bad expansion valve
The compressor pushes the Freon pressure to the expansion valve where the valve restricts flow, similar to putting your thumb over a garden hose. When the Freon exits the expansion valve at high pressure and high velocity it becomes cold
If you have a 98 or newer civic there is a door where there would be a cabin filter behind the glove box. If you take off that little plastic cover you can reach in and try to remove debris inside to help the evaporator core and the expansion valve regulate the pressure by blowing air through the core
Old Jul 18, 2020 | 04:51 PM
It shows you've been a member here for 18 years! Congrats! Have you had the same civic this whole time on honda-tech or have you had several? Random question I know but just curious
Old Jul 18, 2020 | 05:21 PM
tony_2018's Avatar
Fish Twig
Its possibel the fan isn't spinning fast enough, I've had that happened.
Old Jul 18, 2020 | 06:18 PM
I have also had that happen. The condenser fan usually fails completely within a few days or weeks of that happening
Old Jul 21, 2020 | 10:02 AM
dgdarien's Avatar
Hah, yeah same Civic, original owner.
dgdarien's Avatar
It was a thought I had but when I look at it when it's on, it spins pretty darn quick.
