Transmission flush vs change?
So I just bought a 1998 Honda Accord EX, 190k. I’m getting some hard shifts, and when I look at the trans fluid dipstick, it is the right color and doesn’t appear burnt, but am worried the previous owner may have just done a drain and fill and put some cheap transmission fluid in it. Should I do just a drain and fill once, or do the “flush” where I repeat the drain and fill 3-4 times? Thanks!
If you are going to drain, drain it the 3-4 times way.
Also, take the shift solenoids off and inspect to make sure the filters on them are not clogged, that can also cause the issue.
Daniel Carter
Apr 10, 2019 11:35 AM
micahd02
Aug 3, 2018 12:44 PM
charlescee
Nov 19, 2013 08:15 PM
sjala76
Mar 19, 2013 08:08 PM
