I Cant get a stock gsr running with Hondata NEED HELP!!!
Old Jul 10, 2020 | 02:36 PM
kellerspec05's Avatar
Default I Cant get a stock gsr running with Hondata NEED HELP!!!
I have a p06 ECU that i added the vtec and the s300 to. i did the installation myself . i have a b18c1 with a skunk2 intake manifold. no other mods. i just put the motor in, it's freshly rebuilt. the s300 seems to be working fine i can do datalogging with it. i have uploaded the preloaded p72 calibration and the engine just runs like crap. RPMs bouncing between 400-650 and it smells rich. when i switch out the ECU with a stock p28 the engine seems to run alot better i can actually drive the car and vtec works too. i followed the hondata troubleshooting guide and it seems like nothing is wrong with the s300 but i just dont get it. i have also sent pictures to HAmotorsports and they said everything with the ECU looks good. can someone please help me? i disabled closed loop and that didnt make a difference. on the data log ignition keeps randomly jumping between 1 degree and 5 degrees, is that normal? Also the only fault code is for knock sensor.
Old Jul 10, 2020 | 07:37 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: I Cant get a stock gsr running with Hondata NEED HELP!!!
Make sure the settings in the Hondata are set for a stock engine, check the MAP sensor make sure its on stock map, and injectors are pre set to stock size injectors, also makes sure to sync the timing with the ECU/hondata. You can Try a different base map from the vault or contact Pheriable.net for a better base map and make sure these settings are saved at stock settings.
Old Jul 11, 2020 | 03:42 PM
NVturbo's Avatar
O.G. triple O.G.
is the settings set to a VTEC ecu? Not sure about Hondata but there's an option for this on Neptune RTP
Old Jul 11, 2020 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Double check your ECU component installation... and if all appears to be correct, upload a stock P28 calibration and see if the engine runs just like it does when you plug in the stock P28 ECU. If it doesn't run the same, it is likely that you have issues with your P06 ECU (socketing ?).
Old Jul 12, 2020 | 10:25 AM
thanks for the replies. map sensor and injector size and all parameters seem to be good. the stock p72 basemap should be fine for a stock b18c1. i dont have a timing light so i wasnt able to sync but i dont think a few degrees is going to make the amount of change i am seeing in the engines performance at idle plus i tried to turn the distributor all the way in both directions and it didnt make much of a difference. i do have vtec enabled in smanager. i did exactly that with the p28 calibration and the stock p28 ecu and they run totally different which is why i had HAmotorsports look at my p06 with the vtec/hondata and they said everything looked good. maybe i should have my p28 sent in for the s300 to be installed???
Old Jul 12, 2020 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Yup... let a professional socket the ECU.
Old Jul 13, 2020 | 03:49 AM
Beside HAmotorsport and Phearable does anybody else do ecu services, preferably close to chicago?
smoked08
Jan 10, 2011 02:50 PM
gurlracer_camille
12
Nov 21, 2006 12:16 PM
debogsr
Jan 18, 2006 12:22 PM
Nextelbuddy
Jul 4, 2004 03:28 PM
fred92htch
Sep 6, 2002 01:29 PM
