Replaced steering rack, now won't start
1999 Honda Civic EX 1.6L 2 door coupe D16y8
Replaced the power steering rack and now it won't start. Strange. It does crank over (starter sounds healthy). Battery fully charged. Fuel pump primes. New alternator. Everything worked fine before the rack replacement. Is it even possible I could have missed something that could result in a no start situation? It was running fine before I parked it in my garage (ended up being 3 weeks) to replace the rack. This has me perplexed. Or pure coincidence?
I wonder if the starter is failing. Although it does spin the engine, it makes a continuous cranking sound, as apposed to a more rhythmic cranking sound when attempting to start.
You can try to pop start it in 1st gear if its a 5spd to see if its a bad or weak starter. Double check the alternator connections since you replaced that too.
So.... I've done the tests on the distributor as mentioned in the Haynes manual. All checks out. BUT...... I noticed the roter appeared burnt on the end (the magnetic end). I could be getting weak spark. I know I'm getting fuel (pulled the fuel line to the rail, turned key to ON, the pump primed and fuel spilled out of the line.)
I plugged a spark tester on one of the wires and the bulb did pulse. But again, it might be weak spark.
I'm doing more tests this week
As for the alternator, that was replaced months ago so I'm certain that is not to blame. All fuses are good by the way.
The starter is cranking the engine.
Did you unplug the fuel injector clips or spark plug wires for the rack job?
Did you unplug some engine sensor connectors during your rack work? For example, a common mistake is to swap the 2-pin IAT sensor and power steering pressure connectors.
Stay focused on No-Start 101 diagnostics.
Have you checked the mechanical timing?
Any CEL codes?
If all above are fine, compression test the cylinders.
Any CEL codes?
Any CEL codes?
Any CEL codes?
To clarify, the car was running fine before. I parked it in garage for the rack replacement. Sat for about 2 months while I worked on it here and there. Gotta be something simple. My guess is by sheer coincidence the distributor rotor went bad. It is burnt on the end as mentioned. I have another distributor from another Civic I'm gonna test it with to be sure.
No CEL.
Regarding the common mistake of swapping the IAT and PS press. connector..... What sensors are these exactly? The IAT I assume plugs into the intake tube, but where is this PS press. connector? I can't see how I could have swapped any sensors but it's possible I suppose. In fact, I don't recall unplugging any such sensors , except the obvious O2 sensors to drop the exhaust to get the steering rack out.
Timing was never changed prior to rack replacement.
Swapping the IAT sensor and PS pressure connectors can blow the ECU without throwing a CEL. If you only disconnected the O2 sensor, then a connector swap seems unlikely. To be safe, however, you might consider posting pics of the connector wires for the IAT sensor and PSP switch, which is located under the IM above the rack. I think PSP has a green wire and a black wire.
Timing belts can skip a tooth even when just cranking the engine.
Post a picture. Weak spark could cause a no start. If the rotor is the culprit, then the coil may have been damaged.
This is the correct wire orientation right? Just making sure :
You can lightly sand the rotor contact point, but it doesn't look too bad.
How do the points inside distributor cap look?
I haven't used a spark tester. How do the instructions tell you to interpret the result?
Yes, the diagram is correct for the plug wire firing order.
Have you verified the fuel injectors are pulsing fuel?
Is it possible the cylinders are fuel flooded? This would lower compression and cause a no start. This may be consistent with the abnormal cranking sound you mentioned.
So this spark tester I just got is one that simply plugs into the plug wire and has a bulb that lights when that cylinder fires. Pretty basic.
I haven't verified the injectors are pulsing yet. I'll do this next. Would there be a reason that suddenly there'd be an injection issue? It may be possible the cylinders are flooded. But why I don't know. I'll crank engine over with plugs out to force any gas out.
I can't stress enough how strange this is. Car was fine and I was daily driving it until I parked it in garage to replace the steering rack.
I'll be performing the test you mentioned above, as well as the others previously suggested, in a few days.
I believe your top pic shows pulley rear side.
Use diagram at link also to ensure that you have all parts and that your are assembling them in the correct sequence. The latter is a common problem.
In your pictures, you seem to missing the rear and front pulley face plates.
https://www.bernardiparts.com/Honda/...&assembly=1691
By the way. It appears as though I've figured it out. Not knowing exactly what "it" is. Replaced the complete distributor. Car started right up. Perhaps it was the rotor, perhaps something internal I missed. I never "throw parts at it" but in this case I just swapped the whole thing to see what'd happen. Looks like this mini nightmare may be over. It's due now for a timing belt service, so I may look into that next. I'd be paying a shop because I fear I wouldn't get it on correctly and completely screw up the timing and such. Would you recommend dealer service or a private mechanic? I don't know any reliable Honda techs near me.
I'm skeptical.
Perhaps your spark detector device fails to recognize weak spark.
Skip hiring a mechanic and instead spend the money on a good Milwaukee impact wrench. Removing the crank pulley bolt is by far the most difficult part of the job. A good impact wrench will remove the crank bolt in about 2 seconds or less.
And buy only HONDA parts for the job - water pump, timing belt, valve cover gasket, oil seals, drive belts, etc.
I'm skeptical.
And buy only parts for the job - water pump, timing belt, valve cover gasket, oil seals, drive belts, etc.
