93 Accord CB7 gaskets
Hello. I am in Australia and it looks like a have a leaky oil pan gasket. Can anyone give me the OEM part number for my 93 Accord? Or A part number that will fit. Also If I am going to remove the oil pan I will have to remove the exhaust from the manifold. I called my local Honda parts store and he said that model doesn't show a gasket for the exhaust flange in his drawing. Is this true. It seems to be a sort of triangular shaped gasket with 3 stud holes. Anyone have a part number for this? Preferably a Honda one. It looks like the Honda parts system doesn't recognise parts other than Honda parts. Lastly I need the the small oil seal that goes inside the distributor, over the shaft. I don't think there is one anywhere in Australia. The number I have for that is BH3888E, but of course Honda doesn't recognise it. Thanks
Oil pan Gasket - 11251-P0A-000
Exhaust manifold to head gasket - 18115-PT0-004
Exhaust down pipe gasket - OEM manifold to down pipe flanges use steel/graphite O-Rings
Single pipe - 18212-SM4-003
Double pipe - 18212-SB2-961 x 2
Dist.O-Ring (26.43 x 3.1) TEC - 30110-PA1-732
Hello. Thanks for the part numbers. The one you gave me for the distributor is the external o ring. I need the internal one that goes over the shaft. The number I have for it is BH3888E but I can't find it anywhere in the country. Is there an alternative?
