Why is the timing belt cover bolt spinning??
Old Jul 3, 2020 | 10:34 AM
Rich Gouette's Avatar
Icon4 Why is the timing belt cover bolt spinning??
Hi lads, I've started my water pump/timing belt replacement job...
I'm to the "remove the upper cover(timing belt)...
But the forward bolt(nearest front of car) is just spinning...
I see NO way for there to be a nut anywhere behind...
Is it simply stripped?
Any suggestions as to how I can get this guy OUT?
Thanks much!
Rich
Old Jul 3, 2020 | 11:01 AM
Default Re: Why is the timing belt cover bolt spinning??
I've done a google search, and I'm seeing a number of folk who have encountered this on other cars, and in these cases, there was a
nut recessed into the plastic, and that plastic has rounded off... causing a spinning bolt: in which case, there's no option
but to rip off the cover..
Is this what I'm facing?
Old Jul 4, 2020 | 02:17 AM
hondaslave1342's Avatar
I used a putty knife..pry the cover a bit while turning the nut at the same time
Old Jul 4, 2020 | 07:38 AM
yeah, I tried all manner of things shoved down on that thing..
I gave up & forked out the $ for a new set
thanks for the reply!
R
Jimster480
Nov 11, 2010 08:04 AM
methos713
May 5, 2008 08:01 PM
JDN169
Nov 7, 2006 07:49 AM
ranta18
Jul 9, 2003 12:41 PM
smkngsr
Jun 30, 2002 08:53 PM
