Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2014 Accord LX - Unknown noise/vibration
Old Jul 2, 2020 | 01:07 PM
SlowDriver74's Avatar
Default 2014 Accord LX - Unknown noise/vibration
My wife's car has a low tone noise/vibration from somewhere in the front, that gets louder the faster we go, and seems to be related to wheel speed, not engine rpm. Car seems to run fine otherwise. I have done regular maintenance including transmission fluid replacement. Replaced all tires last week (with good Michelines). Replaced front brake pads and rotors today. Noise persists.
I'd think if it was related to engine, e.g. hole in exhaust header, it would change with rpm.
The tone isn't a warble type, like you might expect from a bad tire. It just gets louder the faster we roll. The vibration seems merely to be a product of the noise, as the car is otherwise smooth.
Old Jul 2, 2020 | 06:21 PM
foumer's Avatar
W95 gives me a hard-on
Default Re: 2014 Accord LX - Unknown noise/vibration
Might be a wheel bearing.
Old May 20, 2023 | 08:05 PM
88CReXin's Avatar
I have the same issue with my 13 Sport manual. I've changed brakes and rotors. Mine seems to be coming from the front left side
Old Jul 13, 2023 | 07:39 PM
pprince72's Avatar
Check the intermediate drive shaft ( passenger side) that has a bearing in the support bracket. I replaced mine and fixed it. If it looks like oil is around it that is the grease gets so hot it looks like oil. Socket and hammer and seal. Drain transmission otherwise it comes out when you pull the axle. Bad news is outer shaft has to come out to get to the inner shaft.
my_hondaetown
Aug 2, 2012 10:56 PM
lucerojamie3
Sep 26, 2011 08:35 PM
mike001
Nov 20, 2005 06:50 AM
1hotintegra
Jul 12, 2004 05:21 PM
