Did a swap now hazard button turn on ignition switch
Swapped a B16, rom ex cluster, p30 ecu and ran/pinned the 3 vtec wires from engine bay harness to exu on my 94 eg dx hatch. Everything works even vtec cracks but problem is when i remove key from ignition the car stays running. I press on the hazard lights button and car turns off. So when pressing hazards ignition goes, cluster lights go on and fuel pump primes even without key in igntion switch. Also the blinkers dont blink and green arrows on cluster dont even come on at all. Had this swap on my other eg just transferred it over to my other one. Btw i used oem b16 harness HELP!!!
Re: Did a swap now hazard button turn on ignition switch
PROBLEM SOLVED!!! When removing the hazard button and the entire bezel, there was a connector that was kind of hiding. There are 2 similar connectors one smaller that also fits into hazard button. That one is for the clock, a clock that my car dont even have haha. They were switched, my girl help me put things back together. PLUGGED IN WRONG CONNECTOR, CLOCK INSTEAD OF THE HAZARDS!!!
