Bad intake valves/seats?
Old Jun 22, 2020 | 01:32 AM
shawnmarsbar's Avatar
5 Year Member
Default Bad intake valves/seats?
Hey all,first post and would like to say thanks for all the knowledge that everyone has passed on, its helped me out alot,thank you
Now on topic, I've recently replaced the engine in my 5th gen prelude h22a4 which runs great, so now I have a spare engine to play with. I started to pull apart the head and came across what I think might be an issue with the intake valves and seats.
Is this salvageable
The valve looks to me to be extremely warm out which is not a big deal as it can be replaced but i don't know what to think about the seat. Is it toast or can it be re ground and put back into action?
Old Jun 22, 2020 | 06:23 AM
Ryanthegreat1's Avatar
Default Re: Bad intake valves/seats?
New valves and a valve job. Probably a good idea to also have new valve guides pressed in.
Not terribly expensive just make sure the machine shop is comfortable with small valves.
Old Jun 24, 2020 | 12:54 AM
5 Year Member
What do you think would have caused the valves to wear down like this,? Would adjusting the valve lash to tight possibly cause excessive wear on the valve?
Old Jun 24, 2020 | 05:48 AM
That is an intake valve so, bad air filtering. Everything that I have pulled apart that had valves that looked like that had K&N air filters on them. Too much grit getting by the filter and eroding the valve.
Old Jun 24, 2020 | 10:44 AM
5 Year Member
Good to know, getting rid of my k&n filter today,thanks
schneedrache
Jul 13, 2013 04:23 PM
thumper64
Jul 25, 2010 05:14 PM
big_daddy234
11
Jul 13, 2009 07:38 PM
fatpride111
29
Nov 14, 2008 09:01 AM
