2000 EX Power Mirrors Help - bad switch wiring?
Old Jun 14, 2020 | 08:32 PM
Brock Webb's Avatar
Default 2000 EX Power Mirrors Help - bad switch wiring?
Hello all! Thank you in advance for any and all replies.
I have a 2000 Civic EX with power mirrors. The switch has never worked from the day I bought it, so today I was tinkering with it to see if it is a switch issue or a wiring issue. And honestly, I’m baffled.
I have the service manual with the pin out of the wires and neither option listed matches the colors and layout I have in the vehicle. A google search revealed that the colors I have match a JDM wiring harness. Does anyone have a copy of the JDM pin out?
Also, after I had given up and put it all back together it started actuating my electric door locks?? I have the door lock switch unplugged for an unrelated issue. How is this possible? I’m guessing these are an add on by a previous owner and something in the wiring is jacked.
Old Jun 14, 2020 | 10:21 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Default Re: Power Mirrors Help
Sounds like the P.O. did some craptastic electrical work, and it's up to you to fix it.
Some pictures would be great - start with the switch and the wiring at the plug (in focus!). I want to see if it's something I recognize as originating in Japan. Any evidence of someone being back there already? Soldered wires, electrical tape, inline wiring connectors, etc.?
Old Jun 15, 2020 | 05:31 AM
muellersfan's Avatar
Default Re: 2000 EX Power Mirrors Help - bad switch wiring?
Post all wire colors attached to the switch connector (and pics of connector as mentioned). Does the connector have 7 or 9 wires?
You can figure out the problem without the JDM circuit diagram.
Start here:
Use a multimeter to test whether the unplugged switch connector gets battery voltage and ground. Since the wire colors don't match the USDM/CDM diagrams, then test all wires for both voltage and ground.
Post wire colors that have battery voltage or ground.
deschlong
121
Aug 11, 2023 12:15 PM
maor_bz
May 17, 2017 06:15 AM
Dr. Willy
43
May 9, 2010 12:45 AM
twinloop
Oct 10, 2007 09:08 PM
groo028
Jul 27, 2006 04:29 PM
