97 Civic HB. CEL P-0441
Old Jun 11, 2020 | 11:55 AM
ddougee's Avatar
Default 97 Civic HB. CEL P-0441
I have a 97 Civic DX that has always been very reliable and well cared for. My CEL came on recently with a P-0441 code. ( EVAP / Purge Flow issue. )
Has anyone dealt with this? The car runs fine for the most part but tends to hesitate bad when the tank is around a quarter full. Feels like it is running out of gas.
I am trying to pinpoint what part of the EVAP system needs to be replaced. Any insight or thoughts would be appreciated. Already replaced the cap since it is a cheap attempt.
Old Jun 11, 2020 | 02:34 PM
muellersfan's Avatar
Default Re: 97 Civic HB. CEL P-0441
What's your skill level with regard to car work (electrical, mechanical, tools)?
Old Jun 11, 2020 | 02:42 PM
ddougee's Avatar
My skill level is moderate. Where is the EVAP Purge Control Solenoid Valve located?
Old Jun 11, 2020 | 06:50 PM
It's on the intake manifold. Follow the vacuum hose on the canister.
Old Jun 12, 2020 | 09:42 AM
ddougee's Avatar
Thank you for this diagram! Very helpful. I will look at it this weekend.....
Old Jun 25, 2020 | 10:16 AM
ddougee's Avatar
I replaced the EVAP Purge Solenoid Valve and the CEL went off but I still have the same sputtering and hesitation symptoms that it feels like I am running out of gas when I get below a half a tank. When it acts up like this, I pull over and turn the engine off. When I restart the car, it drives fine with no sputtering or hesitation for about a mile and then it starts acting up again. I will make it to nearest gas station and fill up. Usually takes about 7 gallons and the car drives fine again until I get below a half a tank again. What should I try next?
Old Jun 25, 2020 | 01:09 PM
Any real or pending codes currently stored in ECU?
Have you recently done a full tune up?
(Tune up = plugs, plug wires, rotor, ignition timing and fuel filter.)
In addition, sputtering and hesitation when the gas level is low may be caused by an old damaged fuel pump sock. Inspect it.
Old Jun 25, 2020 | 01:33 PM
ddougee's Avatar
In the recent past couple months I have replaced the Fuel pump, Fuel filter, IAC Valve, new Plug wires, new NGK plugs, new cap and rotor, changed out all fuel injectors, swapped out distributors, and installed new purge control solenoid valve. I have not checked if there are any codes still in the ECU since there is no CEL on currently. I will check again and let you know. do you still think I need to check fuel pump even though it is only been on the car for 2 months?
Old Jun 25, 2020 | 02:20 PM
Did you check the ignition timing?
Have you test the fuel pressure regulator?
Old Jun 25, 2020 | 02:38 PM
ddougee's Avatar
Timing is good. How do you check the fuel pressure regulator?
Old Jun 25, 2020 | 02:44 PM
ddougee's Avatar
I did just swap out the regulator when I swapped out the entire fuel rail. It did not cause an improvement.
Old Jun 25, 2020 | 03:03 PM
Because the FPR is controlled by the attached vacuum hose, it's best to compare fuel pressure readings with and without the FPR hose attached.
How did you check the ignition timing? What outcome indicated that the timing is good?
Old Jun 25, 2020 | 09:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
When you replaced the fuel pump, did you install a new fuel sock on the bottom of the pump ?
Jagdoc
Oct 14, 2016 05:30 AM
---NON-VTEC---
May 22, 2016 08:32 AM
danielfleenor
Jun 10, 2014 07:30 PM
97civicdx
Aug 27, 2013 04:36 PM
heartpownda17
Apr 1, 2011 11:40 PM
