D16y8 swap on a 1990 civic hatchback ef
Old Jun 11, 2020 | 10:13 AM
90efhatch123's Avatar
Default D16y8 swap on a 1990 civic hatchback ef
I currently have a d15b1 and I’m planning on switching to a d16y8 was wondering if I need a new wiring harness and ecu. Looking for whatever knowledge you all can tell me.
Old Jun 11, 2020 | 10:02 PM
EFDXinATX's Avatar
Default Re: D16y8 swap on a 1990 civic hatchback ef
You will need an mpfi conversion for sure, and that should be your first search. You can modify your original harness or buy a custom swap harness, but either way, you will be doing SOME depinning and most likely a lil soldering. The amount of harness modification required will depend on which ecu you choose. You have an obd0 car and an obd2 motor. I think changing your entire car to obd2 is possible, but waaaaay more trouble than it's worth. You will want to choose between obd0 or obd1, the latter having far more tuning options.
Flaco argento
Jul 29, 2017 11:44 PM
DomaniEM1
Mar 15, 2017 09:45 PM
SenseiRice
Apr 23, 2016 02:23 AM
luis007
11
Apr 6, 2016 04:33 AM
