VTEC Solenoid/ Check Engine light
Old Jun 8, 2020 | 07:53 AM
Rgarza_5ive's Avatar
Default VTEC Solenoid/ Check Engine light
Hello guys I’m new to this forum and my car knowledge is very minimal, I have a question. I just bought a 2000 civic ex, but the engine was swapped and has a y7. So I have a Check engine light for the vtec solenoid, how do I go about solving the light issue? And I obviously don’t need to replace the solenoid if there isn’t a vtec engine, right?
Old Jun 8, 2020 | 08:03 AM
tony_2018's Avatar
Fish Twig
Default Re: VTEC Solenoid/ Check Engine light
They swapped engines but didn't swap ecus.
Old Jun 8, 2020 | 08:06 AM
Ok. Thank you. Would you consider this a big deal? And when I drive and feels like the vtec is supposed to “kick in” it like hesitates (if that’s the right word), anyway to solve that problem as well?
Old Jun 8, 2020 | 08:43 AM
NVturbo's Avatar
O.G. triple O.G.
YOU
DO
NOT
HAVE
VTEC
Old Jun 9, 2020 | 04:15 AM
DaX's Avatar
DaX
Loved
Community Favorite
Do you have to pass emissions or an inspection? If not, you could just deal with having the CEL on constantly and drive the car. Since the ECU is not detecting the VTEC solenoid, it will not try to switch over to the VTEC fuel or timing maps. It will stay in the low cam map. The ECU is not "tuned" for a Y7, so while it will work, it is not ideal. This may be related to the reason you are feeling hesitation, but that hesitation has nothing to do with the engine trying to go into VTEC. Ideally you would either switch to the correct engine (D16Y8) or switch to the correct ECU (P06...this would require an OBD2 to OBD1 conversion harness).
Old Jun 9, 2020 | 08:50 AM
Thank you for taking the time to explain it to me! Really appreciate it!
Old Jun 9, 2020 | 08:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Find a P2E ECU and plug it in. They are not in high demand and therefore, will not be very expensive. The appropriate part number is 37820-P2E-A12.
vtec maniac
Jun 21, 2010 05:53 AM
813tampa
Apr 10, 2008 02:59 AM
813tampa
13
Mar 17, 2008 10:47 AM
springfieldcivic
15
Jun 24, 2005 02:26 PM
