B20VTEC w/ ITR Pistons: stay 84mm, or go with 84.5mm
Old Jun 7, 2020 | 08:14 PM
Team Loyalty's Avatar
5 Year Member
Default B20VTEC w/ ITR Pistons: stay 84mm, or go with 84.5mm
I have a b20v with a gsr head and my head gasket was going and my number 2 piston ring was going I had a compression of 210 and number 2 had 180. So I took the motor apart and got acl main bearing and bearing std size and I got itr 84:5 piston with rings can I use my old rods and I got new arp rod bolts to . My ? Is do I need to take the crank to get shave or balance or anything eles I need to do the crank was good and all the old bearing was perfect I didn’t see any metal or bad marks or ruff spots was all smooth so it’s all this stuff plug and play or do I need anyrning eles . Yes the block going to Machine shop to get it bore to 84:5 cause I see a small mark on number 2 piston wall.machine Told me he mite could sand it down alittle and keep it at 84 but I was thinking should I let them do that or shoukd I just go to 84:5
Old Jun 9, 2020 | 08:42 PM
JKaze's Avatar
10 Year Member
Default Re: B20VTEC w/ ITR Pistons: stay 84mm, or go with 84.5mm
It is simple. Measure a bore diameter and roundness, if it is out of tolerance (quess, most likely are), machine it to next over size.
Old Jun 9, 2020 | 08:47 PM
5 Year Member
yes block went to machine shop and was off from 84 so he doinf it to 84:5 to make sure it’s all good thankx for the information and I had a ? Now head gasket I seen a lot said 84:5 ;40 and 84:5 30: and diff 84;5 which gasket ti need I know I need 84;5 but I don’t know what the other mean
Old Jun 9, 2020 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
40 and 30 refer to how thick the head gasket is... in thousandths of an inch. Standard thickness is .030". If your block or cylinder head has been milled to clean up the surface, then you need to add to the head gasket thickness to get the overall install height and quench area back to original.
Old Jun 10, 2020 | 01:12 PM
5 Year Member
thanxk for much for the information yes I just got thr head back and he had a shave he told me a little bit so which one should I get the .40 or .30
Old Jun 10, 2020 | 01:15 PM
5 Year Member
And another ? I just got my itr piston 84.5 and block bore to 84.5 from machine shop going to use my stock rods with new bearing and rods bolts do I need to take the crank to get resurfaced and balance
Old Jun 10, 2020 | 09:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Depends on how much he "shaved" off...
If the crank was fine when you took the engine apart, there is no reason to turn the journals or re-balance.
Old Jun 10, 2020 | 10:00 PM
5 Year Member
Yeah old bearing good and crank look smooth I had a bad piston ring was going bad but wasn’t that bad but no bearing was bad and he just told me he didn’t even shave a lot just shave to clean it up
Old Jun 23, 2020 | 06:14 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
What's wrong with 85?
liquidzorch
Nov 21, 2011 07:26 PM
dj-t
Mar 10, 2009 05:45 AM
bb4socal
Nov 14, 2006 09:07 PM
tomu06
Dec 21, 2005 05:46 PM
BodyKits NW
Mar 17, 2005 01:58 PM
