p0325
having a big problem with my knock sensor keeps throwing code i have done everything know good ecm new wire new knock sensor new distributor new spark plugs rebuilt injectors new fuel filter idk what els to change pls help im super frustrated wit this a t this point
You need a multimeter.
1) Unplug ECU connector C and check for a short to ground at pin C3 (Red/Blu wire).
2) Also test for continuity between pin and the wired pin of the knock sensor connector.
speshuled619
Jul 26, 2002 10:23 AM
