Honda Wiring Concerns
Old Jun 5, 2020 | 08:55 PM
Adam Kuszak's Avatar
Default Honda Wiring Concerns
Im a northern michigander who has been a honda enthusiast for a while. I started my first Trail rail project which is a Volkswagen frame, steering, and suspension, but runs on a 97 honda civic d16 motor and 5 speed tranny i built for my civic. This is the first time I've ever tried to run a PGM FI motor outside the vehicle. I scrapped everything minus the main engine harness, the ecu, and i have the PGM FI relay with connector, among many other things(Radiator, FPR, Ect.) from the car. I wanted to wire in an aftermarket fuse box i picked up with only the necessities. I have the OEM Honda service manual with all the diagrams, but as i said am new to making a standalone system. Can anyone help guide me towards a good source for information for pinning out accessories and repinning the necessities.
Any help is appreciated.
Old Jun 5, 2020 | 09:00 PM
Default In case anyones curious
Here's some pictures of the project so far...
Old Jun 6, 2020 | 03:14 AM
muellersfan's Avatar
Default Re: Honda Wiring Concerns
Originally Posted by Adam Kuszak
I have the OEM Honda service manual with all the diagrams...Can anyone help guide me towards a good source for information for pinning out accessories and repinning the necessities.
Can you be more specific?
Old Jun 7, 2020 | 07:05 AM
Default Re: Be more specific
I want to delete all my accessories, and hardwire my ignition and fuel pump to switches using the stock ECM and get rid of the rest of the wires i dont need, and cant find any threads or posts online on stripping and rewiring my harness for just the necessities to make my motor run.
Old Jun 7, 2020 | 07:12 AM
Default ECM diagrams from the manual that i have
Old Jun 7, 2020 | 08:36 AM
chrysler kid's Avatar
It's a very basic fuel injection motor that relies on the distributor, crank phaser, coolant and air temp readings to operate the fuel injection and timing system.
So my advice is to keep everything in the engine harness minus the AC system.
The ecu is triggered by a reference signal from the key so there is no antitheft or trickery involved with ecu power and motor function
So run everything off of the stock ecu, wire in your own trigger for ecu power from a switch. Let the ecu command the main relay and read cam, crank, coolant, air, and exhaust readings and that's my general over view
Old Jun 7, 2020 | 02:53 PM
So basically supply power on a switch to...
Plug-A pin-11 and pin-24 ...
And then ground Plug-D pin-13?
That really is as easy as it gets
Old Jun 7, 2020 | 04:07 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
How do you plan to shift the transmission? Z linkage?
Old Jun 7, 2020 | 05:52 PM
Wow
Old Jun 7, 2020 | 08:17 PM
Manual cable linkage. It lines up almost perfectly with the frame. Weld in a bracket and mount the linkage to that. Probably get one out of a scrap car at a junkyard.
Old Jun 11, 2020 | 09:22 PM
Well the advice helped, thank you very much for the input. I'll be creating a new post or moving this one soon. Everything minus the fuel pump and lights are wired in now! I appreciate you guys! 😁
Old Jun 12, 2020 | 05:08 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Fuel cell in the front? Or is that thing gonna be a wheelie machine?
Old Jun 12, 2020 | 07:25 AM
I'm hoping it'll pull the tires. Not sure where I'm putting the fuel cell yet. Been winging it as far as design goes. I'll be sure to keep updating. I only work on this thing once a week.
Old Jun 12, 2020 | 11:48 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
It's a cool build for sure. I've always wanted to take a D series and build a go-kart around it. My idea was to use an auto trans to get away from the shift linkage issue, but I'm definitely looking forward to your idea.
KS Hwang
Apr 26, 2013 07:04 AM
Sheppy25
Honda Civic (2006 - 2015)
Mar 4, 2013 01:27 PM
Syndacate
Jul 25, 2006 11:35 PM
redex94
Audio / Security / Video
Nov 4, 2003 04:58 PM
SuzukaBlueAP2
Acura TL, RL & ZDX
Sep 10, 2003 05:29 AM
