PR3-3 head / best matching block?
Old Jun 5, 2020 | 06:02 PM
Michael Urteaga's Avatar
Default PR3-3 head / best matching block?
I just purchased a PR3-3 1999 head and was wondering what’s the best block to use on it? Also is this a type R head?
Old Jun 5, 2020 | 08:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: PR3-3 head / best matching block?
There was no 1999 ITR cylinder head available here in the US. So if it is in fact an ITR head casting, it would have to be from over-seas. Now, something to consider: Both a B16A and an ITR cylinder head start out as the same casting... the ITR simply has better valves, dual valve springs, bigger cams and a slight bowl cleaning at the short radius just inside the valve face compared to the B16A. If you add dual valve springs and Titanium retainers, performance valves, bigger cams and fully porting and polishing the intake and exhaust runners... is it either a B16A or ITR head ? The answer is no... it is a PR3 head casting that has been vastly improved.
Old Jun 5, 2020 | 08:25 PM
Thanks for the info.. any ideas on a block to match? I hear a b20b block is a good one?
Also came with dual Springs on the intake and exhaust but can’t be sure their oem
Dioxine
Jan 15, 2012 07:09 PM
98_Coupe
Mar 31, 2007 07:09 PM
ninjaturtle1023
Jul 26, 2004 06:32 AM
RacnGSR
Aug 17, 2002 11:40 PM
275Performance
Feb 1, 2002 09:13 AM
