Showa - Steering gear overhaul - drill a hole?
Old Jun 1, 2020 | 05:49 PM
mcruaro's Avatar
Default Showa - Steering gear overhaul - drill a hole?
I am trying to overhaul a civic 2008 steering gearbox for the first time.
I am trying to understand the technical Honda Civic manual at: Steering Gearbox Overhaul - Power Steering
My problem is that I am confused to understand what is the purpose of drill a hole through the cylinder house (please, see step 11 of the above link or the image below) to remove the cylinder end.
Why should I drill something in the cylinder house? I suppose that is to remove the cylinder end, but I cannot realize what is the implication of this hole.
Thank you guys in advance for some useful help!
Civic service manual referece:
Step 11
. Drill a 3 mm (0.12 in.) diameter hole about 2.5-3.0 mm (0.10-0.12 in.) in depth in the staked point (A) on the cylinder. Do not allow metal shavings to enter the cylinder side on the gearbox housing. After removing the cylinder end (B), remove any burrs at the staked point.
Old Jun 7, 2020 | 06:00 AM
Ryanthegreat1's Avatar
Default Re: Showa - Steering gear overhaul - drill a hole?
To release the threads for that nut. They use a punch to stake the nut in place so it can't back off. Drilling the stake out allows removal of the nut without destroying the threads.
You don't need to drill clear through. Just enough to pierce the case and remove the staked in material.
Old Jun 7, 2020 | 06:22 AM
mcruaro's Avatar
Thanks. So I suppose that the hole is used to remove threads *throught* the hole, similar as in the koyo steering box, where there is a orifice where you remove the metal orings while spin the nut. Weard, showa requires to drill a hole instead to make the case with one.
The chances to ruin the steering box are higher.
Eric Brooks
Jul 22, 2017 08:44 PM
scottishz
Feb 14, 2017 10:43 PM
bsclywilly
Audio / Security / Video
Jun 2, 2007 08:33 AM
OldSchoolHatch
24
Jun 6, 2003 08:23 PM
